A very reasonable response, thank you. And I see WinBox is available for Mac now! I didn’t realise you could export the config as commands, and was disappointed to find my backup, which doesn’t work, is not decipherable!
Okay, here’s my config. I generally do all this config (the things in my OP) through the “Quick Set” and “Advanced” tabs in the web interface (which seems pretty on par with WinBox?).
# 2025-07-12 08:17:40 by RouterOS 7.19.3
# software id = REDA-CTED
# model = C52iG-5HaxD2HaxD
# serial number = REDACTED
add admin-mac=RE:DA:CT:ED:RE:DA auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=IRL disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.mode=ap .ssid=IRL2 disabled=no \
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=REDACTED
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.88.100 client-id=1:RE:DA:CT:ED:RE:DA mac-address=\
RE:DA:CT:ED:RE:DA server=defconf
add address=192.168.88.69 client-id=1:RE:DA:CT:ED:RE:DA mac-address=\
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment=IMAP dst-port=143 in-interface-list=\
WAN protocol=tcp to-addresses=192.168.88.100 to-ports=143
add action=dst-nat chain=dstnat comment=IMAPS dst-port=993 in-interface-list=\
WAN protocol=tcp to-addresses=192.168.88.100 to-ports=993
add action=dst-nat chain=dstnat comment=DSM1 dst-port=5000 in-interface-list=\
WAN protocol=tcp to-addresses=192.168.88.100 to-ports=5000
add action=dst-nat chain=dstnat comment=DSM2 dst-port=5001 in-interface-list=\
WAN protocol=tcp to-addresses=192.168.88.100 to-ports=5001
add action=dst-nat chain=dstnat comment=DSM3 dst-port=6690 in-interface-list=\
WAN protocol=tcp to-addresses=192.168.88.100 to-ports=6690
add action=dst-nat chain=dstnat comment=SVN dst-port=REDAC in-interface-list=\
WAN protocol=tcp to-addresses=192.168.88.100 to-ports=REDAC
add action=dst-nat chain=dstnat comment=SVNS dst-port=REDAC \
in-interface-list=WAN protocol=tcp to-addresses=192.168.88.100 to-ports=\
REDAC
add action=dst-nat chain=dstnat comment=SSH dst-port=REDAC in-interface-list=\
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Australia/Sydney
/tool mac-server
/tool mac-server mac-winbox
Looks like everything is here. One thing I did notice though, was I forgot to set the WiFi country at first. When I corrected that to “Australia” and re-exported, the new configuration.country=Australia appeared, but the channel.band=5ghz-ax and channel.band=2ghz-ax settings disappeared! Maybe nothing, but I’ve often wondered whether setting the country is what would make my experience different from the thousands that must otherwise be using this router in a similar way.
