Does quouting quotes of quotes in consecutive post make any sense?
The problem is the button “FAR AWAY”.
It loses importance…
The “quote” button appear to be the natural function to write a reply to the newbie
and also from some distracted forum guru (or who ignore it because they don’t bother him the quotes)
and often it is not laziness that does not delete the excess parts in a quotation,
but it appears as perfectly normal that there is the whole quoted piece above …
Near-Solution
add a confirmation popup “you really want quote?” when try to quote…
surely discourages the use of quote than “post reply”
and put the button “post reply” on right place, instead far away from the last post
on unusual and strange position, surely NOT ergonomic
Since MikroTik do use phpBB, everything can be tweaked.
Here is one thread about quoting.
https://www.phpbb.com/community/viewtopic.php?p=15506426#p15506426
You concord on what I have wrote? :slight_smile:
next example <1% of comment
Next one
Next example: Maybe 10% of text is a new text. The rest is quotting
Please stop harassing forum users about this question. It is more annoying than quotes. Thanks.
Simply change on the phpbb administrator panel the limit of nested quotes from 5 to 2?
This change might help but not in most of cases. It seems that one of typical Reply abuses is when users hit Reply to a lengthy post just to express their agreement (one-liner). Reducing number of nested quotes wouldn’t help in this case.
OTOH sometimes it is really useful to be able to nest more than one layer of quotes (but indeed not very often).
But a reply to one-liner do not report again the 3rd nested long post if the one-liner reply to the reply…
My view on this matter is that no amount of automated restrictions will make this problem go away (and keep forum usable for discussions), the only feasible way is to enforce certain level of netiquette on users. I’m with @BartoszP on that, I just don’t know if his way of doing it is the best (but I can’t judge, I’m not forum moderator).
If still necessary the 3rd, 4th and 5th layer of quotes,
I have doubts about the intelligence of people who do not remember what they wrote before
or the laziness of going to review the third layer…
Also smile are disabled, but if is needed:
¯_(ツ)_/¯
For me limiting the max nested quote to 2
and
set a message >Please not abuse [OK]< when press the "
Solve the problem because the users are lazy and prefer skip mesage pressing “+ Post Reply” instead…
Why not just remove the quote button, so when you like to quote, you need t do it manually with [ quote][ /quote]
I just found out that I can remove email when some quote me …
At this point why not use cleartext and remove HTML?
Also why strikeout is missing, and must be done manually?
AMEN @normis AMEN
IMO, the quote feature is very useful and People should learn how to edit quotes so that this capability is used properly. Unfortunately many are too lazy to learn how to use QUOTES properly.
@normis, please re-enable the :slight_smile:
Smilies are still on for signature, but do agree that it should be open for normal posting :slight_smile:
****:blush:
It’s about :mrgreen: the unicode :person_beard: works indipendenlty… :slight_smile:
Hallelujah, Hallelujah … so what is your proposition how to teach people to use it properly?
