Does R11e_LR8G provides fine timestamp ?
I have just noticed a new version of the LORA8 minipci card (and a new WAP LORA8G gateway).
In the marketing material it claims better sensibility and GPS timestamp
Does this mean with this module, received packets have fine timestamp based on GPS so we can track lora nodes based on TDoA ?
Thank you
Antonio
Hola ?
Nobody from Mikrotik can answer this? The documentation is not clear about this.
Thank you
Antonio
GPS is an added functionality with the new LR8G cards, so you can have the device report a “dynamic” GPS location to the server (instead of previously only-static/manually set coordinates).
It does not support “fine-timestamps”.
