Hey all.
Just updated to 6.44 and my throughput (specifically download speed) has plummeted to a ridiculous, near un-usable, level. I’m running with a pretty much near default config/settings (of which, NONE have been adjusted before/during/after the upgrade!) - so I’m really not sure what the cause of the issue is!
Anyone else noticed a drastic drop in speed since 6.44 (stable) - and if so, what did you do to get back to your normal speeds??
Thanks in advance,
://mk.
