I configured MPLS and I got those Flags and MPLS dont work at all.
I tried everything but I don’t get the issue.
R1 - CONFIG
add name=LOOPBACK
set [ find default-name=ether2 ] mtu=1530
/port
set 0 name=serial0
add address=10.0.0.1 interface=LOOPBACK network=10.0.0.1
add address=192.168.1.1/30 interface=ether2 network=192.168.1.0
/ip dhcp-client
add interface=ether1
/mpls interface
add disabled=no input=yes interface=dynamic
/mpls ldp
add disabled=no lsr-id=10.0.0.1
/mpls ldp interface
add disabled=no interface=ether2 transport-addresses=10.0.0.1
/system identity
set name=R1
/system note
set show-at-login=no
/tool romon
set enabled=yes
R2 - CONFIG
add name=LOOPBACK
set [ find default-name=ether1 ] mtu=1530
/port
set 0 name=serial0
add address=10.0.0.2 interface=LOOPBACK network=10.0.0.2
add address=192.168.1.2/30 interface=ether1 network=192.168.1.0
/ip dhcp-client
add disabled=no dst-address=0.0.0.0/0 gateway=10.0.0.1 routing-table=main \
suppress-hw-offload=no
/mpls interface
/mpls ldp
add disabled=no lsr-id=10.0.0.2 transport-addresses=10.0.0.2
/mpls ldp interface
add disabled=no interface=ether1 transport-addresses=10.0.0.2
/system identity
set name=R2
/system note
/tool romon
set enabled=yes
Note: I try to do the same config on physical router and I get the same flags.
