Want to help a friend of mine who own a small business, but got stuck configuring Wireguard over two WAN.
Situation:
- small town in the mountains with frequent Internet failures - the need of two Internet connections;
- simple failover config it would be sufficient, but, as he pay for both, PCC was considered as better option;
- a number of 5 persons working remote - the need for Wireguard setup;
- equipment: 2 HAP ax2, if everything goes as planed, main router will be an RB5009 and first two will be used as APs.
Problem:
Can not access local network over Wireguard session when both WAN interfaces are active. Found at least six discussions regarding this topic, here on forums, but wasn’t unable to solve the issue.
With both WAN interfaces active, I can initiate a working Wireguard session, either on WAN1 or WAN2, and can ping the router 192.168.88.1, but can not access none of others LAN devices.
With only one WAN active (either one) everything goes fine.
The config:
# 2025-06-08 11:00:44 by RouterOS 7.19.1
# software id = ---
# model = C52iG-5HaxD2HaxD
# serial number = ---
add admin-mac=48:A9:8A:D5:EB:C0 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] disabled=yes name=ether1-orange
set [ find default-name=ether2 ] name=ether2-digi
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether2-digi name=pppoe-digi \
password=--- use-peer-dns=yes user=---
/interface wireguard
add comment="Wireguard server" listen-port=13231 mtu=1420 name=wireguard \
private-key="---"
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=miniLAN
/interface wifi channel
add band=5ghz-ax disabled=no name=wifi6 skip-dfs-channels=10min-cac width=\
20/40mhz
add band=2ghz-ax disabled=no name=wifi4 skip-dfs-channels=10min-cac width=\
20mhz
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes name=security \
passphrase=---
/interface wifi configuration
add channel=wifi6 country=Romania disabled=no mode=ap name=wifi6 security=\
security ssid=---
add channel=wifi4 country=Romania disabled=no mode=ap name=wifi4 security=\
security ssid=---
/interface wifi
# operated by CAP 48:A9:8A:6B:39:EC%bridge, traffic processing on CAP
add configuration=wifi4 disabled=no name=cap-wifi1 radio-mac=\
48:A9:8A:6B:39:F1
add configuration=wifi4 disabled=no name=cap-wifi2 radio-mac=\
48:A9:8A:6B:39:F2
# no connection to CAPsMAN, managed locally
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration=wifi6 configuration.manager=capsman-or-local .mode=ap \
.ssid=--- disabled=no security.authentication-types=\
wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
configuration=wifi4 configuration.manager=capsman-or-local .mode=ap \
disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes \
.ft-over-ds=yes
add address-pool=default-dhcp interface=bridge name=defconf
/routing table
add disabled=no fib name=digi
add disabled=no fib name=orange
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
/ip smb
set enabled=no
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/ip settings
set rp-filter=strict
/ipv6 settings
set disable-ipv6=yes
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=\
all wan-interface-list=all
add comment=defconf interface=ether1-orange list=WAN
add interface=wireguard list=LAN
add interface=pppoe-digi list=WAN
add interface=bridge list=miniLAN
/interface ovpn-server server
add mac-address=FE:B5:58:8B:42:3A name=ovpn-server1
/interface wifi cap
set certificate=none discovery-interfaces=bridge enabled=yes
/interface wifi capsman
set enabled=yes interfaces=bridge package-path="" require-peer-certificate=no \
upgrade-policy=none
/interface wifi provisioning
add action=create-enabled comment="---" disabled=no master-configuration=\
wifi4 radio-mac=48:A9:8A:6B:39:F1 slave-configurations=wifi4 \
slave-name-format=""
wifi4 radio-mac=48:A9:8A:6B:39:F2 slave-configurations=wifi6
add action=create-enabled comment="Local 1" disabled=no master-configuration=\
wifi4 radio-mac=48:A9:8A:D5:EB:C4 slave-configurations=wifi6
add action=create-enabled comment="Local 2" disabled=no master-configuration=\
wifi4 radio-mac=48:A9:8A:D5:EB:C5 slave-configurations=wifi6
/interface wireguard peers
add allowed-address=192.168.80.2/32 client-address=192.168.80.2/32 \
client-dns=192.168.88.1 comment="---" interface=wireguard name=\
wg1 private-key="---" \
public-key="---"
add allowed-address=192.168.80.12/32 client-address=192.168.80.12/32 \
client-dns=192.168.88.1 comment="Test" interface=wireguard name=\
wg11 private-key="---" \
public-key="---"
192.168.88.0
add address=192.168.80.1/24 interface=wireguard network=192.168.80.0
/ip dhcp-client
# Interface not active
add address=192.168.88.0/24 comment=defconf dns-server=\
1.1.1.1,8.8.8.8,8.8.4.4 gateway=192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="allow WireGuard" dst-port=13231 \
protocol=udp
established,related,untracked
invalid
in-interface-list=!LAN
add action=accept chain=forward comment="Allow forward for Wireguard Bridge" \
in-interface=wireguard out-interface=bridge
add action=accept chain=forward comment="Allow forward for Bridge Wireguard" \
in-interface=bridge out-interface=wireguard
disabled=yes ipsec-policy=in,ipsec
disabled=yes ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=change-mss chain=forward new-mss=clamp-to-pmtu protocol=tcp \
tcp-flags=syn
add action=mark-connection chain=prerouting comment=\
"Mark NEW INPUT connections FROM Digi" connection-mark=no-mark \
connection-state=new in-interface=pppoe-digi new-connection-mark=\
digi_conn
"MARK NEW INPUT connections FROM Orange" connection-mark=no-mark \
connection-state=new in-interface=ether1-orange new-connection-mark=\
orange_conn
add action=mark-routing chain=output comment=\
"Mark NEW OUTPUT connections TO Digi" connection-mark=digi_conn \
new-routing-mark=digi
"Mark NEW OUTPUT connections TO Orange" connection-mark=\
orange_conn new-routing-mark=orange
"PCC LAN - Digi 2/0" connection-mark=no-mark \
connection-state=new dst-address-type=!local in-interface-list=miniLAN \
new-connection-mark=digi_conn per-connection-classifier=\
src-address-and-port:2/0
"PCC LAN - Orange 2/1" connection-mark=no-mark \
new-connection-mark=orange_conn per-connection-classifier=\
src-address-and-port:2/1
add action=mark-routing chain=prerouting comment=\
"Mark FORWARD FROM LAN - Digi" in-interface-list=miniLAN \
"Mark FORWARD FROM LAN - Orange" in-interface-list=miniLAN \
add action=masquerade chain=srcnat comment="NAT - DIGI" disabled=yes \
ipsec-policy=out,none out-interface=pppoe-digi src-address=\
192.168.88.0/24
add action=masquerade chain=srcnat comment="NAT - Orange" disabled=yes \
ipsec-policy=out,none out-interface=ether1-orange
add action=masquerade chain=srcnat comment=\
"masquerade - simply WAN" ipsec-policy=out,none \
out-interface-list=WAN
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
90.84.225.1 routing-table=orange scope=30 suppress-hw-offload=no \
target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
pppoe-digi routing-table=digi scope=30 suppress-hw-offload=no \
target-scope=10
/ip service
set ftp address=192.168.0.0/16
set ssh address=192.168.0.0/16
set telnet address=192.168.0.0/16 disabled=yes
set www address=192.168.0.0/16 disabled=yes
set www-ssl address=192.168.0.0/16 disabled=yes
set winbox address=192.168.0.0/16
set api address=192.168.0.0/16 disabled=yes
set api-ssl address=192.168.0.0/16 disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Bucharest
/tool mac-server
/tool mac-server mac-winbox
Can you point me in the right direction or pin point the errors I made ?
Thank you!
