Dual Xeon CPU Support...
Has anyone loaded MikroTik OS onto a Dual Xeon Server motherboard? I’m looking for a router that will handle PCI-x GB network interface cards and most motherboards with PCI-x slots are configured for dual Xeon processors.
Will MikroTik make use of two CPUs? Will MikroTik even run with dual CPUs?
Is there a limit as to how much bandwidth the MikroTik OS can handle or is it only hardware limited?
Thanks,
Brad Belton
I think I remember reading somewhere that the second CPU will be ignored. You could save yourself a bunch of money and get an Opteron-based motherboard. Especially since Xeons are quite slow (compared to their desktop counterparts, wheras the Opterons are right up there performance-wise).
As for bandwidth, it seems as though Mikrotik scales fairly well, but I haven’t tried it at gigabit speeds yet.
no! see: http://www.mikrotik.com/docs/ros/2.8/guide/specs.content
(we have an older p3 dual cpu running the MROS, but this might be working by chance)
there are lots of threads about bandwidth in the forum. (haven’t seen a gbit/s condition, though)
it depends much from the application.
matthias
no software limit. a few gigabits throughput has been seen in tests.
Thanks for everyone’s replies.
I’ll look into the Opteron-based motherboards and see what I find.
Hello Normis!
Thanks again for the Intel six PCI slot motherboard feedback. I bought one and as far as I can tell it works like a champ. It’s currently configured with two RB44’s and two single port NICs.
What hardware was used on the GB speed tests?
Best,
Brad Belton
Intel server board with Intel Xeon processor.
