Dude server
hi all.
Can somebody tell me, does Dude has option when the ping goes hight to show you the AP is down.
I did configuration and work good but I want when the ping is high to show me the AP is down, even is not down I just want to know about latency .
thx selim.
dude checks several services when all of them is down, then node is considered down.
if you set that only test is ping, then you will have it down, but you can be alerted even if node is unstable (some of services go down)
thx for respond. Janisk
But doesn’t have any special option to make like nagios, when is ping high to show you critical ping or something like that or to show you the Ap is down. Can explain more about test ping.
thx selim .
