Dumb AP: Static IP and DHCP Client
Hey guys,
I configured my fist hap ac2 with Quick Set as “Home AP”. All working fine. I then decided to put ether1 to the bridge, too. So I can use it as additional port and can run package updates (seems that has to be port 1). Also working fine.
My question: under IP > Addresses I now have a static IP as well as an IP from the active DHCP client (IP > DHCP). I now thought I could deactivate the DHCP client as the static IP would enough but then I also lose the Gateway address and DNS server coming over the DHCP client. How do I configure the Gateway and DNS server without DHCP client? Or should I just let it be and let the AP have two IPs?
Thanks a lot for your explanation!
You can add a default route under IP > Route and a DNS server under IP > DNS. Alternatively if the router you are connecting this Mikrotik to supports static DHCP leases you could assign an address that way.
Thanks for the tips! I am slowly getting the hang of it.
I now deactivated the DHCP server and the DNS server is now empty. In Routes there is still one entry left:
Dst. Address 192.168.3.0/24 with Gateway %bridge - and everything still works fine. All devices still do get correct IPv4 and IPv6 addresses and DNS servers. Is that too good to be true or just how it should be? I rebooted already several times.
What did not work was searching for package updates on the router. So I put the entry
Dst. Address 0.0.0.0/0 with Gateway 192.168.3.1 back in place. Now that works too. DNS still empty. Is it that simple?
Thanks a lot!
For the route, yes. I suspect updates worked because the DNS entry was cached, add 192.168.3.1 as a DNS server too.
RouterOS can be rather a steep learning curve, it is basically linux underneath with a custom user interface on top.
See the example below culled from this link… https://forum.mikrotik.com/viewtopic.php?t=182276
Assumes no vlans, just bridge and etherports… and assumes the main subnet is 192.168.1.0 …
The example on the link has vlans…
add ingress-filtering=no name=bridge
add name=management
/interface wireless
as required
as required
add bridge=bridge interface=ether1
set discover-interface-list=management
add interface=bridge list=management
add address=192.168.1.x/24 interface=bridge network=192.168.1.0
set allow-remote-requests=yes servers=192.168.1.1
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.1.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=x.x.x.x
set api disabled=yes
set winbox address=as-required
set api-ssl disabled=yes
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=management
Very helpful and everything works as expected. Thanks you guys, very much appreciated!
