Dynamic Firewall
I like to set firewall for PPPoE Users on there user name, can any one suggest how can i able to set that firewall rule, the user name is only static, remain all things are dynamic, even IP address is also dynamic
Rgds
Nishit
hi
if you want to set static username and password for pppoe user’s,it is simple.and you don’t need to create firewall rule.
you can create a new entry in secret and set your username and password,for ip address,you can create a pool and assigne this pool to the your secret.
what exactly do you want to do? if you need to firewall some user by its username - create PPPoE Server (under Interfaces, not under ‘PPPoE Servers’) and set necessary username. then use this interface in your firewall rules as ‘in-interface’ or ‘out-interface’
