E3372h-320 USB/lte1 problems constantly LTE1 link up-down
I’m little bit affraid about using non-stable, beta release.
It’s my home router but it is like production environment and it’s heavilly used specially these days.
GTK
That’s a choice you’ll have to make for yourself. The 4G stick will work, and my CCR1036-8G-2S+ has been running 7.0b8 for 27 days now without issues. Except that on the CCR1036-8G-2S+ with 7.0b8…tadaa..the USB port doesn’t work, so I still can’t use the stick where I want it :laughing:
MT is aware of the issue, and it should be fixed in the next beta. But that’s CCR1036-specific, it all worked fine on my hAP ac.
After the update hAP ac to version 7beta8, the modem Huawei E3272h works fine, but the wifi (CAPsMAN) stops working normally, some clients cannot connect (disconnected, received deauth: class 3 frame received (7)).
If you roll back to version 6.47.1, then everything is ok with wifi, but the modem does not work.
They work quickly :slight_smile: The problem was fixed in 7.1beta1 (2020-Jul-21 08:58):
!) added FastTrack and NAT hardware offloading support for CRS317-1G-16S+RM;
!) ported features and fixes introduced in v6.47.1;
*) route - added rpki-check;
*) route - bgp improvements;
*) route - do not allow modifying/deleting “main” table;
*) route - fixed incorrectly interpreted prefix states received from RTR;
*) route - fixed IPv6 ECMP connected routes;
*) route - fixed IPv6 policy routing;
*) route - routing rules improvements;
*) wireless - fixed wireless performance for 802.11b/g/n and 802.11a/n interfaces on non-ARM architecture devices;
*) other minor fixes and improvements;
Now both the modem and the network are working as expected, thanks
who make fix on rb2011 , this e3372h-320 ?
on rb2011 (mipse) loss os7.0beta
Hi all!
I have exactly the same “blinking lte1 interface” problem with similar configuration (router Microtik hAP ac2 + Huawei 3372h-320 modem, RouterOS v6.47.1)
Hi.
Same problem with Huawei E3372h-320 on hAP ac (RB962UiGS-5HacT2HnT and hAP ac2 RBD52G-5HacD2HnD
Any official or owners solution, except upgrade to 7 beta version?
Same issue here with 6.47.1 on new hex S router.
7.1beta1 fixed it. It would be nice though to have the fix in long-term release.
Multitaps have a specific protocol for reading data that is NOTHING like a pad. If the USB interface only supports pads, you wont be able to use it with a multitap.
same issue!!
Modem: E3272S-153
Mode: HiLink
Same issue with MikroTik hAP ac and Huawei E8372h-320 (E3372 with Wi-Fi and advanced web interface).
I’m trying RouterOS 6.45.9 and 6.47.2 - no luck
19:44:42 interface,info lte1 link up
19:44:42 interface,info lte1 link down
19:44:44 dhcp,info dhcp-client on lte1 got IP address 192.168.8.100
19:44:45 interface,info lte1 link down
19:44:45 dhcp,info dhcp-client on lte1 lost IP address 192.168.8.100 - lease stopped locally
19:44:46 interface,info lte1 link up
19:44:46 interface,info lte1 link down
Only works in new beta.
And probably only when you restart router.
I confirm the problem with the new Huawei modems that Mikrotik can’t digest. It is still difficult to work with the RouterOS beta - some of the functionality does not work or does not work correctly. Developers - please respond, will there be a backport from 7 beta at least in the test 6.48?
I found this topic when it was linked in the 6.47.2 release topic.
I am using 2 of these E3372 sticks, one on RB750Gr3 and another on RB962UiGS-… and both of them work OK on RouterOS 6.47.1
Yes, E3372h-153 works fine.
But last model - E3372h-320 - very not fine… LTE link up/down every 2-3 sec. Supported this model in 7beta2 RouterOS.. Very beta…
Ok I don’t know the submodel of mine, but it is already over a year old so probably the model that works fine on all versions.
Looking forward to a backport.
It looks like there will be no backport from version 7 to version 6. Support hints at switching to version 7.
That would be nice but it’s betabroken.
I had the same problem.
Spent a lot of time and find a solution:
Use another more powerful power adaptor, in my case I fount adapter 12V 5A, power up, and no problem!!!
My setup Mikrotik RBD52G-5HacD2HnD-TC (7.1Beta2) + E3372h-320
