E3372h-320 USB/lte1 problems constantly LTE1 link up-down
I can confirm E3372h-320 the same behavior on my HEX-S Router. Upgrading to latest 7 beta RouterOS will broke setup, in particular
PoE Out not work properly (then my WiFi AP not powered)
PPPoE SFP VDSL link constantly up and down
Downgraded to latest 6.x LT version and all fine again (except E3372h-320 of course)
Possible workaround - find the way to disable mass storage
But as I understand the solution will be only with RouterOS 7 release (is someone know when this may happen?)
hEX RB750Gr3 running 6.47.7 firmware + Huawei E3372 running 10.0.3.1 (H192SP2C983) firmware = flapping LTE interface.
My provider says they can connect to the USB stick and change some services. Not sure what does it mean but let’s see what happens next.
that modem can have many differ firmwares who works differ way.
support@mikrotik.com or mikrotik.com/support
Unfortunately, this version (320) cannot be changed to another firmware, at the moment. All changes are completely prohibited and there is no workaround.
Why isn’t a MBIM driver added to version 6 of ROS?!? :frowning:
Probably true, until it not be sell to RU then 4pda.ru not do a firmware and not publish that info at bez-kabli.pl where dzeik have his repo: https://www.mediafire.com/folder/ll9ieqqooyhy5/Documents
Because KERNEL cannot use it.
I also have this issue using a hap Ac2 and E8372h-320. An upgrade to ROS 7 resolves the issue but that release is not stable.
I found this solution on 4pda. That firmware supposed to let E3372h-320 work with ROS 6.xx
Same problem here… just bought a new E3372h-320 as well. I’ve got a BT-branded E3372 and that works fine. Will have to see if that firmware upgrade helps?
Hmm, I think I might simply return it to Amazon and not have to faff with translating that website/unknown firmware. Shame…
Anyone got a reference for a E3372 model that does work with v6.x? Clearly this branded BT one works.
Starting with 7.1beta6 my E3372h-320 is working. With beta5 I had continous lte1 interface up & down.
Returned my 3372h-320 as I need it to work with v6.x - still looking for confirmation as to which models do actually work…
I have same problem. Link up / link down neverending.
I don’t understand why version 6 is called stable when it makes such a problem and also after about five hours the Mikrotik router ended restarts on its own based on the USB dongle connected in this way.
Ironic, because the current v7 doesn’t work with LTE at all.
Well, it is not a problem that was designed in by MikroTik, but it is caused by a change in the device you bought from somewhere else.
The original E3372 worked fine, but then this E3372h-320 device was introduced and people assume it is supported by RouterOS because it says E3372 is
supported. However, that is a different device, which works OK. The E3372h-320 is not supported.
The device has the same chip and even the same revision number. The only thing the change is that autorun is loaded in a different way (it shifts the volume after the driver is installed) and the driver has been updated to a newer version. Support for the iMac is also added. The number 320 specifies only the geographical area and defines only the set of contained channels. These channels can be changed via AP commands, as long as the device is not locked and there is no need to enter an unlock code.
So it’s all just a matter of software. Just release an update that could accept a slightly different way to connect.
Otherwise, there is no problem with device detection. Mikrotik identifies the device and even correctly. The problem is that after identifying and connecting the device, it disconnects it again after about three seconds and then connects it, and so on.
H is define for HiLink… Mikrotik should solve this, because Huawei plans to equip HiLink with all other new USB modems as standard.
Yes it apparently is being worked on in v7.
I do have 3 of the older E3372 in operation without any problem, so it must be something that has changed.
Yes I’ve tested in v7 as well and yes, it works. Hence the reason I started the thread about v7 release dates and stability.
This is a tidge frustrating - very difficult to find out if there is a specific E3372 model that works. Could you post part numbers?
Thx…
I find new bug… In 7.1rc4 RouterOS not changed APN to IPv6. And missing parameter “IPv4 and IPv6”
Still look for a reference/part numbers for the E3372 that work in RouterOS v6. Wouldn’t think it would be so hard :frowning:
i have huawei e3372h-320 usb but it’s not working with RB5009UG+S+IN the router can’t see the huawei
