E50UG Scheduler Script: ‘Not Allowed by Device-Mode’ when using /tool fetch
Hello MikroTik Community,
I am trying to automate blocking bad IPs on my hEX E50UG (Level 4 license) using a scheduler script. My script fetches the Emerging Threats blocklist from the internet and updates the firewall address list.
Here’s my script (simplified for clarity):
# Remove old bad IPs
/ip firewall address-list remove [find list=bad_ips]
# Fetch Emerging Threats blocklist into memory
:local fetched [/tool fetch url="https://rules.emergingthreats.net/fwrules/emerging-Block-IPs.txt" mode=http as-value output=user]
:local content ($fetched->"data")
:local lines [:toarray $content]
# Add IPs to firewall
:foreach ip in=$lines do={
    :if ([:typeof $ip] = "str" && [:pick $ip 0 1] != "#" && $ip != "") do={
        /ip firewall address-list add list=bad_ips address=$ip
When I try to run this script manually or via the scheduler, I get the following error:
failure: not allowed by device-mode
Observations:
  • I’ve tried output=user (fetch into memory) to avoid file writes, but it still fails.
My questions:
  1. Is this a known restriction on hEX E50UG device mode?
  2. Is there a recommended workaround to automate fetching and updating IP blocklists via scheduler on E50UG?
  3. Can this limitation be bypassed without external servers, or is it a security restriction by design?
Thank you in advance for any guidance!
You need to enable in device-mode the corresponding item (probably "fetch")-
Open a terminal amd issue in it:
/system device-mode print
You may have it set to "home" or "basic" and you might need to change it to "advanced", see:
