Only when it gets to zero and os does NOT release space causing out of memory condition, there is an issue.
Otherwise nothing to worry about. Memory is supposed to be used.
Wyz4k's graph shows storage memory. Unlike RAM, persistent disk space is not meant to be filled with unnecessary data until it is full.
Fair remark !
(I missed it was about disk space)
In that case check if something is logging to your device storage space.
If not, there may be an issue indeed ...
@Wyz4k what device is this ? From your earlier remark (and looking at the disk space) I assume something with 16Mb storage ?
I’m testing on two wAP R AC devices at the same time.
There are two persistent auth files in the storage which do not change and aren’t written to again, and then one file that gets overwritten.
/interface wireless scan wlan1 duration=10 save-file=scan.txt background=yes
I only have one of those files in my storage, but the OS may not be correctly deleting the previous version of this file when it gets overwritten.
Would it be possible to move, for example, wifi-qcom-ac package to external USB flash stick to get more free space on internal flash?
Nope.
That would be considered a security risk.
well.. it took just two years ![]()
What's new in 7.24.6 (2026-10-30):
*) system - stop the flash configuration store from growing on dynamic configuration changes;
What's new in 7.23.8 (2026-10-08):
