My router has a total of three ISP exits. I tried using ISP1 and ISP2 as ECMP routing tables and allowed some devices within the local network to use this ECMP routing table outgoing gateway. The other devices use the default main outgoing gateway.
However, the problem is that after I set everything up, this specific device(10.0.0.130) did not follow the expected ECMP routing table and instead accessed the internet through the default gateway(pppoe-out8).
I checked many times, but still couldn’t find out where the problem was, and the mikrotik help documents also did not have any relevant guidance.
I hope that experts within the community can help me out. Below is my configuration.
@MikroTik] > export
# 2024-12-07 21:13:40 by RouterOS 7.16.2
# software id = xxxxxxxxx
# model = CCR1036-12G-4S
# serial number = xxxxxxxxxx
set [ find default-name=ether1 ] disabled=yes
set [ find default-name=ether2 ] disabled=yes
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes
set [ find default-name=sfp3 ] disabled=yes
set [ find default-name=sfp4 ] disabled=yes
/interface pppoe-client
add disabled=no interface=sfp2 name=pppoe-out8 user=<pppoe-username>
/interface macvlan
add interface=ether5 mac-address=B2:54:05:89:BA:8B mode=private name=macvlan1
add interface=ether5 mac-address=F6:4F:AA:AD:82:B6 mode=private name=macvlan2
add interface=ether6 mac-address=42:DB:28:D3:57:FB mode=private name=macvlan3
add interface=ether6 mac-address=DE:E8:E3:5F:A8:00 mode=private name=macvlan4
/interface bonding
add mode=802.3ad name=bonding1 slaves=ether11,ether12
add disabled=no interface=macvlan1 name=pppoe-out1 user=<pppoe-username>
add disabled=no interface=macvlan2 name=pppoe-out2 user=<pppoe-username>
add name=WAN
add name=LAN
add name=LB
add name=dhcp ranges=10.0.0.150-10.0.0.240
add address-pool=dhcp interface=bonding1 name=dhcp1
/routing table
add disabled=no fib name=ecmp
add disabled=no fib name=CMIP_route
/ip settings
set ipv4-multipath-hash-policy=l4
add interface=sfp1 list=WAN
add interface=pppoe-out8 list=WAN
add interface=pppoe-out1 list=LB
add interface=pppoe-out2 list=LB
add interface=bonding1 list=LAN
add address=10.0.0.1/24 comment=defconf interface=bonding1 network=10.0.0.0
add address=10.0.0.0/24 dns-server=119.29.29.29,223.5.5.5 gateway=10.0.0.1 netmask=24
set servers=119.29.29.29,119.28.28.28,2402:4e00::,2402:4e00:1::
add action=accept chain=input comment="accept established,related,untracked" connection-state=\
established,related,untracked disabled=yes
add action=drop chain=input comment="drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="accept ICMP" disabled=yes in-interface-list=WAN protocol=icmp
add action=accept chain=input comment="allow Winbox" disabled=yes in-interface-list=WAN port=8291 protocol=tcp
add action=accept chain=input comment="allow SSH" disabled=yes in-interface-list=WAN port=22 protocol=tcp
add action=drop chain=input comment="block everything else" disabled=yes in-interface-list=WAN
add action=masquerade chain=srcnat out-interface-list=LB
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-table=ecmp scope=30 suppress-hw-offload=\
no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-table=ecmp scope=30 suppress-hw-offload=\
no target-scope=10
add disabled=no distance=10 dst-address=0.0.0.0/0 gateway=pppoe-out8 routing-table=main scope=30 \
suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh address=10.0.0.0/24
set api disabled=yes
set winbox address=10.0.0.0/24
set api-ssl disabled=yes
/ip ssh
set host-key-type=ed25519 strong-crypto=yes
/lcd
set enabled=no
/routing rule
add action=lookup disabled=no min-prefix=0 src-address=10.0.0.130/32 table=ecmp
add action=drop disabled=no dst-address=10.0.0.100/32 min-prefix=0 src-address=10.0.0.130/32
/system clock
set time-zone-name=Asia/Shanghai
/system logging
set 0 topics=info,!dhcp
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
