Hi guys hope you can help with this one.
I have the following setup. RB1000 functioning as a load balancer, it is set up with 2 different ISP’s on 2 ethernet ports. I then use the mangle to mark routing port 80 ,110 ,443 and 25 (per traffic load balancing). My routing table’s 0.0.0.0/0 route for port 80 then has 3 gateways(ECMP) as my one isp is running at 1mbps and the second at 4mbps the gateway for the 4mbps ISP is in twice giving me a ratio of 2:1.
The problem is that this works great for a while but later a simple site like google just doesnt come up. After refreshing a couple of times it comes back ok. Can this be a dns issue? The two ISP’s obviousely use different DNS servers.
Mangle
1 ;;; HTTPS 443 Traffic
chain=prerouting action=mark-routing new-routing-mark=HTTPS 443 passthrough=yes protocol=tcp dst-port=443
2 ;;; HTTP Traffic
chain=prerouting action=mark-routing new-routing-mark=Route HTTP traffic to ECMP passthrough=yes protocol=tcp dst-port=80
3 ;;; FTP Traffic
chain=prerouting action=mark-routing new-routing-mark=Route FTP traffic to ECMP passthrough=yes protocol=tcp dst-port=21
4 ;;; POP Traffic
chain=prerouting action=mark-routing new-routing-mark=POP3 traffic passthrough=yes protocol=tcp dst-port=110
Routes
add comment=“HTTPS Traffic LB1” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=172.168.0.1 routing-mark=“HTTPS 443” scope=30 target-scope=10
add check-gateway=ping comment=“HTTP Traffic ECMP LB1//3” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=172.168.0.1,172.168.4.2,172.168.4.2
routing-mark=“Route HTTP traffic to ECMP” scope=30 target-scope=10
add check-gateway=ping comment=“POP3 Traffic LB2” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=172.168.0.1,172.168.4.2 routing-mark=
add comment=“Default Route EVERYTHING ELSE LB2” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=172.168.0.1 scope=30 target-scope=10 “POP3 traffic” scope=30 target-scope=10
