Elasticsearch, Logtash and Kibana Setup Mikrotik ELK Stak
Dear All Member
Can Anyone Help me about ELK Stak on Mikrotik.
i search in google but can fine solution.
Please Help Mee..
I don’t think anyone will be able to “just help” you with ELK. This is huge topic. Do you have specific problem or just hoping for “how to- step by step” instruction.
There is a topic about Splunk and Mikrotik, you may want to check it if looking for inspiration: http://forum.mikrotik.com/t/tool-using-splunk-to-analyse-mikrotik-logs-3-3-graphing-everything/121810/1
Dear Kamilo
Do you have Tutorial ELK For Mikrotik?
Do you have an ELK installed for other system, or just MT.
I do suggest as kamillo writes have a look at Splunk.
It’s free to use if you log less than 500MB/day.
My Router are heavily logged (many access list with full log) and it logs around 60MB/day.
