I have download from the links in the post and this is what I have config there -
this is the stunnel.conf
; Sample stunnel configuration file for Win32 by Michal Trojnara 2002-2012
; Some options used here may be inadequate for your particular configuration
; This sample file does not represent stunnel.conf defaults
; Please consult the manual for detailed description of available options
; * Global options *
; Debugging stuff (may useful for troubleshooting)
;debug = 7
;output = stunnel.log
; Disable FIPS mode to allow non-approved protocols and algorithms
;fips = no
; * Service defaults may also be specified in individual service sections *
; Certificate/key is needed in server mode and optional in client mode
cert = stunnel.pem
;key = stunnel.pem
; Authentication stuff needs to be configured to prevent MITM attacks
; It is not enabled by default!
;verify = 2
; Don’t forget to c_rehash CApath
;CApath = certs
; It’s often easier to use CAfile
;CAfile = certs.pem
; Don’t forget to c_rehash CRLpath
;CRLpath = crls
; Alternatively CRLfile can be used
;CRLfile = crls.pem
; Disable support for insecure SSLv2 protocol
options = NO_SSLv2
; Workaround for Eudora bug
;options = DONT_INSERT_EMPTY_FRAGMENTS
; These options provide additional security at some performance degradation
;options = SINGLE_ECDH_USE
;options = SINGLE_DH_USE
; * Service definitions (at least one service has to be defined) *
; Example SSL server mode services
socket = l:TCP_NODELAY=1
socket = r:TCP_NODELAY=1
debug = 7
client = yes
[pop3s]
accept = 995
connect = pop.gmail.com:995
[ssmtp]
accept = 465
connect = smtp.gmail.com:465
this is the emailblat.cmd
set dir=C:\Program Files\Dude\blat
set smtpsender=> testing@gmail.com
set smtpserver=127.0.0.1
set smtpport=465
set smtpuser=testing
set smtppwd=1234567
set mailto=> testing@gmail.com
“%dir%\blat.exe” -to %mailto% -f %smtpsender% -server %smtpserver% -port %smtpport% -u %smtpuser% -pw %smtppwd% -subject %1 -body %2
IF NOT EXIST %logname% echo ====================== Start of file ====================== > %logname%
echo. >> %logname%
echo ====================== %time% ====================== >> %logname%
C:
CD %dir%
echo CMD: blat.exe -to %mailto% -f %smtpsender% -server %smtpserver% -port %smtpport% -u %smtpuser% -pw %smtppwd% -subject %subject% -body %body% >> %logname%
my computer IP is - 10.0.0.167/24
the DG is - 10.0.0.1 (IP of the router )
what am I missing? doing wrong?
Thanks ,
