emailing cpu percent
If the cpu uasage goes over a certain set percent then have an email sent to tell you that the routerboard is under a load to look for problems. Has anyone done this? I think I would want it to tell when the cpu hits 50%. thanks
The far more scalable solution would be to implement a monitoring system that monitors your routers and APs via SNMP and can also send alerts. Mikrotik makes The Dude (free), there are other solutions available for free and for pay.
yep - the problem with running a script to check cpu time is that the cpu will increase while the script is running and falsely report usage. CLI scripts seem to take lots of cpu for some reason. you should use the /tools graphing on cpu, or externally monitor via snmp to get a better reading.
