Enable firewall rule from API-SSL
from librouteros import connect, exceptions
# Establish the connection to the Mikrotik router
try:
    api = connect(host='****, username='****', password='****')
    # Retrieve all firewall rules
    print("Retrieving firewall rules...")
    rules = list(api('/ip/firewall/filter/print'))
    # Print all rules for debugging
    print("Firewall rules:")
    for r in rules:
        print(r)
    # Find the firewall rule with the specified comment
    rule_id = None
    for r in rules:
        if r.get('comment') == 'IP Services HTTP':
            rule_id = r['.id']
            break  # Assuming there's only one rule with that comment
    if rule_id:
        print(f"Found rule with ID {rule_id}. Enabling it...")
        # Enable the rule using its ID
        api('/ip/firewall/filter/enable', numbers=rule_id)
        print("Firewall rule enabled successfully.")
    else:
        print("No firewall rule found with the comment 'IP Services HTTP'.")
except exceptions.TrapError as e:
    print(f"Failed to enable firewall rule: {e}")
finally:
    # Close the connection
    api.close()
I can connect to the router through API, but the python script is not enabling the rule.
What am I doing wrong?
