I have an EoIP+IPSec tunnel runing between two locations but I have very poor performance in network speed. I include below the tests performed and my configuration
Machine in site A to public iperf server:
iperf3 -c proof.ovh.net -p 5202
Connecting to host proof.ovh.net, port 5202
[ 5] local 172.26.34.20 port 38740 connected to 141.95.207.211 port 5202
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 118 MBytes 987 Mbits/sec 7346 32.5 KBytes
[ 5] 1.00-2.00 sec 114 MBytes 958 Mbits/sec 8271 26.9 KBytes
[ 5] 2.00-3.00 sec 113 MBytes 946 Mbits/sec 6975 42.4 KBytes
[ 5] 3.00-4.00 sec 114 MBytes 957 Mbits/sec 7243 238 KBytes
[ 5] 4.00-5.00 sec 113 MBytes 949 Mbits/sec 6529 45.2 KBytes
[ 5] 5.00-6.00 sec 114 MBytes 954 Mbits/sec 7832 110 KBytes
[ 5] 6.00-7.00 sec 114 MBytes 954 Mbits/sec 8056 140 KBytes
[ 5] 7.00-8.00 sec 112 MBytes 944 Mbits/sec 7383 60.8 KBytes
[ 5] 8.00-9.00 sec 114 MBytes 954 Mbits/sec 7980 41.0 KBytes
[ 5] 9.00-10.00 sec 114 MBytes 954 Mbits/sec 8315 83.4 KBytes
[ 5] 0.00-10.00 sec 1.11 GBytes 956 Mbits/sec 75930 sender
[ 5] 0.00-10.03 sec 1.11 GBytes 950 Mbits/sec receiver
Machine in site B to public iperf server:
[ 5] local 172.26.34.30 port 35042 connected to 141.95.207.211 port 5202
[ 5] 0.00-1.00 sec 20.8 MBytes 175 Mbits/sec 0 1.16 MBytes
[ 5] 1.00-2.00 sec 42.5 MBytes 357 Mbits/sec 1203 955 KBytes
[ 5] 2.00-3.00 sec 31.2 MBytes 262 Mbits/sec 0 1024 KBytes
[ 5] 3.00-4.00 sec 32.5 MBytes 273 Mbits/sec 0 1.05 MBytes
[ 5] 4.00-5.00 sec 33.8 MBytes 283 Mbits/sec 0 1.08 MBytes
[ 5] 5.00-6.00 sec 33.8 MBytes 283 Mbits/sec 0 1.10 MBytes
[ 5] 6.00-7.00 sec 36.2 MBytes 304 Mbits/sec 0 1.11 MBytes
[ 5] 7.00-8.00 sec 35.0 MBytes 294 Mbits/sec 0 1.11 MBytes
[ 5] 8.00-9.00 sec 35.0 MBytes 294 Mbits/sec 0 1.11 MBytes
[ 5] 9.00-10.00 sec 35.0 MBytes 294 Mbits/sec 0 1.11 MBytes
[ 5] 0.00-10.00 sec 336 MBytes 282 Mbits/sec 1203 sender
[ 5] 0.00-10.03 sec 334 MBytes 279 Mbits/sec receiver
Machine at site A to machine at site B through the tunnel
iperf3 -c 172.26.34.30 -p4242
Connecting to host 172.26.34.30, port 4242
[ 5] local 172.26.34.20 port 52302 connected to 172.26.34.30 port 4242
[ 5] 0.00-1.00 sec 959 KBytes 7.85 Mbits/sec 37 12.7 KBytes
[ 5] 1.00-2.00 sec 573 KBytes 4.69 Mbits/sec 0 33.9 KBytes
[ 5] 2.00-3.00 sec 573 KBytes 4.69 Mbits/sec 21 14.1 KBytes
[ 5] 3.00-4.00 sec 382 KBytes 3.13 Mbits/sec 5 19.8 KBytes
[ 5] 4.00-5.00 sec 764 KBytes 6.26 Mbits/sec 2 21.2 KBytes
[ 5] 5.00-6.00 sec 573 KBytes 4.69 Mbits/sec 2 32.5 KBytes
[ 5] 6.00-7.00 sec 573 KBytes 4.69 Mbits/sec 13 29.7 KBytes
[ 5] 7.00-8.00 sec 764 KBytes 6.26 Mbits/sec 24 18.4 KBytes
[ 5] 8.00-9.00 sec 382 KBytes 3.13 Mbits/sec 13 14.1 KBytes
[ 5] 9.00-10.00 sec 573 KBytes 4.69 Mbits/sec 4 24.0 KBytes
[ 5] 0.00-10.00 sec 5.97 MBytes 5.01 Mbits/sec 121 sender
[ 5] 0.00-10.04 sec 5.63 MBytes 4.71 Mbits/sec receiver
This is my config at site A
IP Addresses:
/ip address print
# ADDRESS NETWORK INTERFACE
0 1.2.3.4/24 1.2.3.0 ether1-WAN
1 172.26.33.253/24 172.26.33.0 bridge-EOIP-A
EoIP Interface:
/interface eoip print
0 R name="eoip-A" mtu=1500 actual-mtu=1500 l2mtu=65535 mac-address=02:6B:BD:C9:12:6F arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m local-address=1.2.3.4 remote-address=4.3.2.1 tunnel-id=150 keepalive=10s,10 dscp=inherit clamp-tcp-mss=yes dont-fragment=no ipsec-secret="XXXXXXXXX" allow-fast-path=no
The bridge:
/interface bridge print
0 R name="bridge-EOIP-A" mtu=1500 actual-mtu=1500 l2mtu=65535 arp=enabled arp-timeout=auto mac-address=06:03:AB:DA:3C:3E protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
Bridge ports:
/interface bridge port print
4 ether5-A bridge-EOIP-A yes 1 0x80 10 10 none
5 eoip-A bridge-EOIP-A 1 0x80 10 10 none
The config at site B
IP Addresses:
/ip address print
0 D 4.3.2.1/32 4.3.2.0 WAN
1 172.26.33.254/24 172.26.33.0 bridge-EOIP-B
EoIP Interface:
0 R name="eoip-B" mtu=1500 actual-mtu=1500 l2mtu=65535 mac-address=FE:DA:E7:5E:75:15 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m local-address=4.3.2.1 remote-address=1.2.3.4 tunnel-id=150 keepalive=10s,10 dscp=inherit clamp-tcp-mss=yes dont-fragment=no ipsec-secret="XXXXXXXXX" allow-fast-path=no
The bridge:
0 R name="bridge-EOIP-B" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled arp-timeout=auto mac-address=E4:8D:8C:39:82:30 protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
Bridge ports:
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
# INTERFACE BRIDGE HW PVID PRIORITY PATH-COST INTERNAL-PATH-COST HORIZON
0 ether06 bridge-EOIP-B no 1 0x80 10 10 none
1 eoip-B bridge-EOIP-B 1 0x80 10 10 none
The two mikrotiks have direct access to internet and have public ip’s, I played with the encryption algorithms and the best result was obtained with SHA-256 + aes-256-cbc. The mikrotik at site A is a VM of CHR with a p10 license activated, the mikrotik at site B is a 1100AHx2.
I see a lot of posts talking about the MTU, but, in my tests, I have not obtained any improvement by modifying the recommended value (1500). I do not know how to correctly calculate the value I should have.
Please, any help is welcome.
Regards
