EoIP tunnel, computers cant ping
I have an EoIP tunnel setup between x86 Mikrotik(6.45.7) and a CHR running on VMwareESXi(6.46.4)
Im trying to have the LAN on each side be in the same subnet, 192.168.1.0/24
Computer 1 on x86 side can ping CHR IP 192.168.1.2 but not computer 2 192.168.1.10
Computer 2 on CHR side cannot ping x86 IP 192.168.1.2 or computer 1 192.168.1.100
Here is my config, any help would be much appreciated
router 1
[admin@SCC-Core] > /inter eoip pr
0 R name="DR-EoIP" mtu=1500 actual-mtu=1500 l2mtu=65535 mac-address=02:CE:B9:7A:32:12 arp=enabled arp-timeout=auto loop-protect=default
loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m local-address=x.x.9.74 remote-address=x.x.113.114
tunnel-id=301 keepalive=10s,10 dscp=inherit clamp-tcp-mss=yes dont-fragment=no ipsec-secret="secret" allow-fast-path=no
[admin@SCC-Core] > /inter bri pr
0 R name="public_bridge" mtu=1500 actual-mtu=1500 l2mtu=9014 arp=enabled arp-timeout=auto mac-address=00:0C:29:DE:F5:2F protocol-mode=none fast-forward=yes
igmp-snooping=no auto-mac=no admin-mac=00:0C:29:DE:F5:2F ageing-time=5m vlan-filtering=no dhcp-snooping=no
[admin@SCC-Core] > /inter bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
INTERFACE BRIDGE HW PVID PRIORITY PATH-COST INTERNAL-PATH-COST HORIZON
0 ether4 public_bridge no 1 0x80 10 10 none
1 DR-EoIP public_bridge 1 0x80 10 10 none
[admin@SCC-Core] > /ip add pr
ADDRESS NETWORK INTERFACE
0 192.168.1.1/24 192.168.1.0 public_bridge
Computer 1
IP address 192.168.1.100/24
gateway 192.168.1.1
Router 2
[admin@DR-Core] /interface eoip> pr
0 R name="SCC-EoIP" mtu=1500 actual-mtu=1500 l2mtu=65535 mac-address=02:6E:42:4F:E5:5B arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off
loop-protect-send-interval=5s loop-protect-disable-time=5m local-address=x.x.113.114 remote-address=x.x.9.74 tunnel-id=301 keepalive=10s,10 dscp=inherit
[admin@DR-Core] /interface eoip> /interface bridge print
0 R name="EoIP" mtu=auto actual-mtu=1500 l2mtu=65535 arp=enabled arp-timeout=auto mac-address=00:0C:29:DE:F7:5F protocol-mode=none fast-forward=yes igmp-snooping=no auto-mac=no
admin-mac=00:0C:29:DE:F7:5F ageing-time=5m vlan-filtering=no dhcp-snooping=no
[admin@DR-Core] /interface eoip> /interface bridge port print
0 SCC-EoIP EoIP 1 0x80 10 10 none
1 ether2 EoIP yes 1 0x80 10 10 none
0 192.168.1.2/24 192.168.1.0 EoIP
Computer 2
IP address 192.168.1.10/24
gateway 192.168.1.2
