I’m trying to establish an EoIP tunnel between an RB411 and an RB433.
Here is my network setup:
x.x.x.x Public IP
[Firewall x.x.x.x =/= 10.0.10.1]
10.0.10.0/24 network
[Windows Small Business Server 10.0.10.115 =/= 192.168.16.2]
192.168.16.0/24 network
The RB411 is on the 10.0.10.x network with the IP 10.0.10.200
The RB433 is on the 192.168.16.x network with the IP 192.168.16.88
I can ping the RB411 from the RB433.
I have a tunnel configured on each RB using the following command on each:
on the RB411:
interface eoip add remote-address=10.0.10.115 tunnel-id=1 mac-address=00-00-5E-80-00-01 disabled=no
ip address add address=10.5.5.1/24 interface=eoip-tunnel1
(note, 10.0.10.115 is the IP of the small business server, which the RB433 is NAT’ed bedhind)
on the RB433:
interface eoip add remote-address=10.0.10.200 tunnel-id=1 mac-address=00-00-5E-80-00-02 disabled=no
ip address add address=10.5.5.5/24 interface=eoip-tunnel1
Is there a way to make sure the tunnel is being established? I can’t ping or access either RB from the other using the 10.5.5.x addresses. Do I need to do anything with the small business server’s firewall/NAT rules? What ports do the EoIP tunnels use so I can pass those through from 10.0.10.115->192.168.16.88
