Error configuring Wireguard in hAP lite
Hello, I’m having problems setting up a WireGuard VPN connection on my Mikrotik hAP lite.
The WireGuard server is self‑hosted on a VPS and it’s working fine from other devices. But when I configure it on my hAP lite, it doesn’t establish the connection with the server. I can see incoming and outgoing traffic in the WireGuard control panel, but on the peer I can only see Tx but no Rx traffic. Using the Packet Sniffer, I found outgoing and incoming traffic on the interface eth1 to (and from) the WG server, using the UDP protocol. I restarted my router before starting, so its configuration is the default one.
I don’t know what I’m missing. Can you help me? Thanks.
My router configuration is:
# 2026-03-10 09:12:35 by RouterOS 7.21.3
# software id = BV2H-JZ1T
# model = RB941-2nD
# serial number = (removed)
add admin-mac=78:9A:18:4C:10:91 auto-mac=no comment=defconf name=bridge
/interface wireless
set \[ find default-name=wlan1 \] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto mode=
ap-bridge ssid=MikroTik-4C1095 wireless-protocol=802.11
/interface wireguard
add listen-port=51820 mtu=1420 name=wg-vpn
add comment=defconf name=WAN
add comment=defconf name=LAN
set \[ find default=yes \] authentication-types=wpa2-psk comment=defconf disable-pmkid=yes mode=dynamic-keys supplicant-identity=
MikroTik
add bridge=bridge comment=defconf interface=pwr-line1
add interface=wg-vpn list=LAN
/interface wireguard peers
add allowed-address=10.8.0.0/24 client-allowed-address=::/0 endpoint-address=212.227.178.150 endpoint-port=51820 interface=wg-vpn
name=peer1 persistent-keepalive=25s public-key="+fSsZjDqVZ1wkyoWujkI7fUPCn96ZvPBLUrdKd3lqwE="
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.8.0.5/24 interface=wg-vpn network=10.8.0.0
/ip dhcp-client
add address-pool=default-dhcp interface=bridge name=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input dst-port=51820 log=yes protocol=udp
add action=accept chain=forward in-interface=wg-vpn
add action=accept chain=forward out-interface=wg-vpn
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1 in-interface=lo
src-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=
fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" connection-state=established,related
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Madrid
/tool mac-server
/tool mac-server mac-winbox
MikroTik\] >
Please use "preformatted text" tag < / > instead of "quote" one
