Hi all
I have downloaded an run dude 6.34rc34 version.
as you can see below, I can’t connect to 127.0.0.1 and localhost with this error message [Error: Connect failed: 10061]
Does anyone have any ideas?
New the Dude builds no longer have windows server option.
The Server is on MikroTik x86, have the same problem. I did like says here http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/MigrationToNewDude
and get “action timed out” error
Time out error will appear on import/export of larger DB files. You can ignore that and try connecting to server after a while. There have been reports that in some cases server disable/enable or system reboot is required so if connection does not work you can try that.
We still need to add some progress indicator for DB import/export actions.
Having same error when trying to connect with client. So I went to the server and did the terminal command
/dude print
all it showed was
error - contact MikroTik support and send a supout file (2)
Steps I took"
- Reboot router.
- Disable dude package, reboot.
- Enable dude package, reboot.
- Uninstall dude package, reboot
- reinstalled dude package, reboot
Still no dice. Anyone else have this issue?
I would like to add that this is a new install of dude, so no previous DBs to import.
After 30 minutes of waiting, I still could not log in to my server, so I restarted it, after the restart it connected. But the happiness did not last long, in an hour this error appears again and restart does not help ![]()
The Dude will not work in v6.33.5. It was uploaded for that version by mistake. You need latest v6.34rc build server and client.
Please check with v6.34rc41 build, if the same problem is there after attempt to import db file then generate supout file and send it to support@mikrotik.com
I had the same problem, but I SOLVED it by doing the following on my Cloud Core Router:
/dude
set enabled=yes
Then the 10061 message went away.
I’m having the same problem on v6.38.1 New installation with database imported. Everything imported successfully, and when I began to modify some of the devices it froze.
I already tried to reboot the router, and restart the dude service.
Please help!
I can’t even get my server to run the command /dude/ It doesn’t recognize it
