Error 'could net load config.json' after restoring containers (x86)
Recently I was forced to do a netinstall to upgrade from 7.18.1 to 7.20.1 after Package upgrade method failed on multiple attempts.
I'm running x86 RouterOS with 4GB of RAM and an SSD.
When I try to start my containers, I get 'could not load config.json'.
Before the upgrade I did settings backup and also used sftp to backup the files (~8GB) including the container directories with UUID type names.
After the upgrade to 7.20.1, I restored the settings and uploaded the files with sftp and rebooted.
I ran 'find' on the backup files on Linux to look for the file, but none of them contain 'config.json'
I created a new test container and looked inside its folder and couldn't find any 'config.json' file.
If this was only 1 or 2 containers, I'd just recreate them, but I have 12 of them and several of them were quite a pain to get configured correctly.
None of them will start (except new test container), they all refer to config.json not loading.
If I create a test container and then try to change the root dir, none of the UUID folders appear in the folder list.
Where is the config.json file? Is it a single file that all the containers share or separate for each container?
In the test container I created, there is no config.json in the root dir container store, so it must be somewhere else/shared.
Also, in Winbox, the UUID folders are properly listed as 'container store' folders.
EDIT: I see this in the release notes, but don’t see how to do it:
EDIT 2:
In version 7.20.1 you can view the config.json if you open the container config in Winbox and scroll all the way to the bottom. The config doesn’t appear immediately, it takes a few seconds to load. Also, it only appears on the containers I’ve recreated, not the ones that were restored from backup.
I suggest creating a ticket to the Support.
it is the same problem I encountered.
Need to recreate the container. Also uncheck the button on “Check certificate”
Same Issue with my mikrotik, after the upgrade to 7.20.1 I have the same issue with a pihole…
no solution found yet…
Yes, some containers need to config manually in order to make them work again.
Pihole may be easier
I use
/container/repull X
That command will generate a:
”could not recreate: missing import data”
response…
I also got a response from Mikrotik support:
”Hello,
Please check the latest public RouterOS 7.21beta3 version; it should be fixed.”
I’ll have to check this latest option.
That could be helpful in other situations, but not in this case. Thanks for sharing that though, I wasn’t aware of that.
I had the same issue after upgrading to RouterOS 7.21.1.
Repulling worked, but it wasn't necessary to turn off the check-certificate option.
To avoid the "could not load config JSON" error, I used the "remote-image" parameter.
container/repull [CONTAINER_NAME] remote-image=[IMAGE_REGISTRY_PATH]
I used Repull button which is available in 7.22rc1 and in Remote Image field I put the path from docker hub (adguard/adguardhome:latest in my case).
This solved the error for me. Also now I have the whole code in Config JSON field as you can see below.
Thank you. This also worked for me
