I noticed that requests to several websites were failing. I used the /tool fetch command to investigate the issue and identify the underlying cause. The command output is provided below:
/tool fetch url="http://github.com "
status: failed
downloaded: 0KiB
failure: ERROR parsing http: too big field size
I do not use adlists, and this issue affects only a few sites, ping command works fine:
ping github.com
SEQ HOST SIZE TTL TIME STATUS
0 20.26.68.64 56 118 3ms744us
1 20.26.68.64 56 118 3ms800us
2 20.26.68.64 56 118 3ms766us
sent=3 received=3 packet-loss=0% min-rtt=3ms744us avg-rtt=3ms770us
max-rtt=3ms800us
jaclaz
November 25, 2026, 3:16pm
2
To me it looks like you are trying to fetch the WHOLE github (which I do believe is rather large).
Try with an actual URL, example:
#DevJoke. Submit a PR if you know a good dev joke.
or
# Dev Joke
#### Send me a PR if you know a good Dev Joke.
Thank you for adding a DevJoke. At text jokes at the **TOP** of the page, add your joke followed by `***`. Add images at the **BOTTOM** with a reference to the image in the README file.
Question - What is the most used language in programming?
Profanity.
Question: Why don't keyboards sleep?
Answer: Because they have two shifts.
This file has been truncated. show original
wfbuton
November 25, 2026, 3:21pm
3
I believe you have to use the RAW url if I'm not mistaken.
yes i can fetch github documentation page:
tool fetch url="https://docs.github.com/en/pages "
status: finished
code: 200
downloaded: 111KiB
total: 18KiB
duration: 1s
I also can fetch
/tool fetch url="https://github.io "
status: finished
code: 200
downloaded: 14KiB
total: 3KiB
duration: 1s
bit can not fetch github on my mikrotik router and all computers connected to the router (ERR_TIMED_OUT browser error).
I can open github on my mobile phone using mobile network.
Amm0
November 26, 2026, 2:06pm
6
64kB limit if it's going to variable.
