Ethernet cards stopped working
I have 2 different x86 servers one with an intel 2 port gigabit pci ethernet card, one with the new gigabit 4 port Mikrotik ethernet card. Both of them worked great worked being the keyword here. The Intel card was fine I believe for a couple months of running idle then just stopped, routeros says the error “couldn’t change the status”. However it will connect up and get the speed/duplex of another machine but no data, unfortunantly I tried to disable and reenable it and it will not re-enable. The 4 port Mikrotik card went out one at port a time.
Everything looks fine in the bios. Not sure if it is driver issues or something else.
here is supout.rif file
[[ admin → deleted madness ]]
This is very strange. After trying everything I could think of with no success I reloaded RouterOS keeping the configuration and they started working again. Will have to monitor these for a couple weeks as I am not comfortable with this machine running my network. Is there possibly an issue in Mikrotik or with drivers?
Don’t post a supout.rif file in the forum! :frowning:
Instead send it to support@mikrotik.com along with your problem.
Tom
