This is semi-related to this post, but I don't want to derail that thread with technical minutiae that isn't related to that thread.
Are packets filtered by ingress-filtering=yes and frame-types=admit-only-untagged-and-priority-tagged counted in any counters?
Does anyone know the significance of the counters prefixed with "driver-"? as in "driver-rx-byte" vs "rx-byte". On my hEX the individual port counters show different values. And currently since the hEX was rebooted, the only a single external device (an ER-X) was connected to each port, and since a different vlan was was connected to each port, traffic would be routed and not switched between the ports. So I was surprised these were different (although they were close in value).
This is the only documentation I was able to find for these counters: RouterOS - RouterOS - MikroTik Documentation where the descriptions for the "driver-" counters have " on device CPU" in the description. So I am assuming the counters without "driver-" are the ethernet packets received or sent at the ethernet ports connected to the switch block. I will need to do some testing where I have multiple ethernet ports in the same vlan, and generate traffic (iperf3 for example) between devices attached to the same vlan. This should be switched traffic, so I would expect the counters without "driver-" to go up, but the driver-* counters to stay reasonably stable. That would be easy to test, so I probably will and report back.
Another possible reason for discrepancy. For a port configured as an access port for a specific vlan, with frame-types=admit-only-untagged-and-priority-tagged, I would expect any tagged frame received on the port to count toward the port rx-packet and rx-byte but not to be forwarded out. There is a counter for "rx-drop" but the documentation has nothing about that, perhaps it is a new v7 or MT7621A addition. But on my hEX S, this is zero.
I just found that you can also dump the switch statistics as well. See Switch Chip Features - RouterOS - MikroTik Documentation This evidently shows traffic from the CPU to the switch chip, i.e. the "internal" trunk between the cpu and the switch. Here's an extract:
Statistics
Some switch chips are capable of reporting statistics, this can be useful to monitor how many packets are sent to the CPU from the built-in switch chip. These statistics can also be used to monitor CPU Flow Control. You can find an example of switch chip's statistics below:
[admin@MikroTik] > /interface ethernet switch print stats
The RB760iGS has two "lanes" to the switch chip so the output of /interface ethernet switch print stats has two counters for each. Extract from manual:
Some devices have multiple CPU cores that are directly connected to a built-in switch chip using separate data lanes. These devices can report which data lane was used to forward the packet from or to the CPU port from the switch chip. For such devices an extra line is added for each row, the first line represents data that was sent using the first data lane, the second line represents data that was sent using the second data line and so on. You can find an example of switch chip's statistics for a device with multiple data lanes connecting the CPU and the built-in switch chip:
[demo@MikroTik] > /interface ethernet print stats
name: eth4-BR-SW_U10_T241 ether1-WAN ether2-BR-SW-Base-U1 ether3-BR-SW-U241 ether5-off_bridge_wrk sfp1
driver-rx-byte: 0 114 003 177 1 638 248 443 395 0 0
driver-rx-packet: 0 1 021 650 14 664 5 291 0 0
driver-tx-byte: 0 315 839 9 711 446 13 412 148 0 0
driver-tx-packet: 0 3 534 135 408 161 284 0 0
rx-bytes: 0 118 089 713 1 697 250 464 495 0 0
rx-packet: 0 2 673 14 661 5 143 0 0
tx-bytes: 0 329 975 10 246 462 13 940 480 0 0
tx-packet: 0 3 522 3 617 13 501 0 0
rx-too-short: 0 0 0 0 0 0
rx-64: 0 435 911 1 963 448 0
rx-65-127: 0 191 171 10 406 4 816 0
rx-128-255: 0 380 779 194 11 0
rx-256-511: 0 13 349 2 062 13 0
rx-512-1023: 0 350 0 0 0
rx-1024-1518: 0 89 40 3 0
rx-too-long: 0 0 0 0 0 0
rx-broadcast: 0 369 352 4 15 0
rx-pause: 0 0 0 0 0 0
rx-multicast: 0 649 624 0 133 0
rx-fcs-error: 0 0 0 0 0 0
rx-align-error: 0 0 0 0 0
rx-fragment: 0 0 0 0 0
rx-overflow: 0
rx-jabber: 0 0 0 0 0
rx-drop: 0 0 0 0 0
tx-64: 0 1 315 121 763 120 209 0
tx-65-127: 0 2 164 429 10 221 0
tx-128-255: 0 4 12 257 29 380 0
tx-256-511: 0 11 959 1 358 0
tx-512-1023: 0 0 0 100 0
tx-1024-1518: 0 40 0 14 0
tx-broadcast: 0 5 3 997 7 996 0
tx-pause: 0 0 0 0 0
tx-multicast: 0 7 127 794 139 785 0
tx-collision: 0 0 0 0 0
tx-excessive-collision: 0 0 0 0 0
tx-multiple-collision: 0 0 0 0 0
tx-single-collision: 0 0 0 0 0
tx-deferred: 0 0 0 0 0
tx-late-collision: 0 0 0 0 0
tx-total-collision: 0
tx-drop: 0 0 0 0 0
tx-fcs-error: 0 0 0 0 0
[demo@MikroTik] > /interface ethernet/switch/print stats
driver-rx-byte: 116 088 343
0
driver-rx-packet: 1 041 645
0
driver-tx-byte: 24 516 747
0
driver-tx-packet: 300 253
0
rx-bytes: 108 410 198
0
rx-packet: 892 760
148 885
rx-too-short: 0
0
rx-too-long: 0
0
rx-pause: 0
0
rx-fcs-error: 0
0
rx-overflow: 0
0
tx-bytes: 344 669
25 373 090
tx-packet: 3 538
296 715
0
[demo@MikroTik] >
