everydns script
I am using mt v3.13, and added the everydns script witch found in wiki:
http://wiki.mikrotik.com/wiki/Dynamic_DNS_Update_Script_for_EveryDNS
but the script did not update the ip
Is there any error in the script?
Regards
Run that script from console and see if there are any error messages.
Hi mrz,
I run it, there is no errors, no results
:sunglasses:
I have updated that script, tested it on v3.23.
Thank you MRZ, but it dose not work in ROS v3.13
Do you have any idea to update it to work with v3.13?
upgrade to v3.23
