Example 1
Failover With Firewall Marking
This example demonstrates how to set up failover with a firewall mangle, filter and NAT rules.
Detailed Section Overview
IP address
In this example, our provider assigned two upstream links, one connected to ether1 and other to ether2. Our local network has two subnets 192.168.1.0/24 and 192.168.2.0/24
add address=10.1.101.18/30 interface=ether1
add address=10.1.200.18/30 interface=ether2( what if this is pppoe)
add address=192.168.1.1/24 interface=ether3
add address=192.168.2.1/24 interface=ether4
Mangle
Connections going through the ether1 interface is marked as “first” and packets going through the ether2 is marked as “other”:
/ip firewall mangle
add action=mark-connection chain=forward connection-mark=no-mark new-connection-mark=first out-interface=ether1 passthrough=yes
add action=mark-connection chain=forward connection-mark=no-mark new-connection-mark=other out-interface=ether2 passthrough=yes
Firewall Filter
When the primary link will fail, we will reject all the established connections, so new connections will pass through the secondary link. The same behavior will happen when a primary link will come back again and here we will prevent local IP leakage to a public network, which is one of masquerades disadvantages:
add action=reject chain=forward connection-mark=other out-interface=ether1 reject-with=icmp-network-unreachable
add action=reject chain=forward connection-mark=first out-interface=ether2 reject-with=icmp-network-unreachable
NAT
Instead of masquerade, we will use src-nat for our local networks, because we do not want to purge connections which are one of the masquerade’s main features when a primary link fails. We will restrict them with firewall rules (later in this example):
add action=src-nat chain=srcnat out-interface=ether1 to-address=10.1.101.18 ( how do i define pppoe here)
add action=src-nat chain=srcnat out-interface=ether2 to-address=10.1.200.18
Routes
We will add two default routes. With distance parameter we set route preference:
/ip route add gateway=10.1.101.17 distance=1 check-gateway=ping
/ip route add gateway=10.1.200.17 distance=2
also suppose if i have static ip on wan 1 and 2 the 2(10.1.200.17) is distance 2 so i cannot connect through winbox from outside unitl i mark connection and then mark routing and put same in routes .
