I have 3 RB411AR Units, v4.6
They are: MAIN, A, B
MAIN → A has WDS
MAIN → B has WDS
Signal Strength is -50dBM
Signal to Noise is 58dB
Tx/RX CCQ is 50/30
That is the reading of the registration for Router A, and the readings for Router B are similar.
There are many metal posts and boats here, but the routers have line of sight.
Any ideas?
Thanks.
EDIT: When I run bandwidth test, the CCQ goes up to around 70/70. Why does CCQ go down with less traffic? Also, even at 70/70, it still seems low.
