:execute output to console? Or any other method?
I’m trying to work around a problem and haven’t yet been able to find a solution
The problem: running either ‘/export terse’ on RouterOSv6 or ‘/export terse show-sensitive’ on RouterOSv7 in order to output the configuration for backup purposes
That’s it, simple right? Maybe, but I can’t figure it out
Detecting which command based on version is doable. I’ve already posted on these forums on how to detect and run version specific commands without failure, i.e. being able to paste in a code snippet that would update wifi details regardless of whether its v6, v7, legacy or wave2 drivers.
The following code snippet will do it via the execute command. Unfortunately :execute does not provide any output to the console
# Get RouterOS Version and extract major and minor versions
:global RouterOS [:pick [/system resource get version] 0 [:find [/system resource get version] " "]]
:global RouterOSMajor [:pick $RouterOS 0]
:local o
:local a ([:find $RouterOS "."]+1)
:local b ([:find $RouterOS "." $a])
:if ($b > 0) do={:set $o [:pick $RouterOS 0 $b]} else={:set $o $RouterOS}
:global RouterOSMinor [:pick $o 2 [:len $o]]
### Version Specific Commands
:if ($RouterOSMajor > 6) do={
:global C "/export terse show-sensitive ; /log warning \"Running RouterOSv7 or above\""
} else={
:global C "/export terse ; /log warning \"Running RouterOSv6 or below\""
execute $C ; /system script environment remove [find where name=C]
i’ve tried outputting the execute results to a file which does work, i.e.
:execute $C file=ConfigOutput.txt
And then with v7 I can use the following to read it to the console
:put [/file get ConfigOutput.txt contents] ; /file remove ConfigOutput.txt
Great!.. but it doesn’t work on V6 it just returns an empty string…???
So i’m stumped, I can’t think of any other way to handle this without errors. At best this could be used to FTP a file to an external location but that’s not what I want. I just need the config spat out in the terminal to be seamlessly integrated with our config change software
Put file=ConfigOutput.txt argument for export command in C variable instead for :execute.
Idk why output to file for :execute on v6 is not working (not having v6 for checking it), but since you need only config export then it is more appropriate to use file argument for export command than for :execute.
Did you check if output to file on v6 is working with something simple like
:execute ":put test1; :put test2; :error err" file=output.txt
It’s this I’m confused by: sending to terminal is different from automation. If your config software can use SSH to issue the “export” command, that will spit out to “terminal”, which presumable be captured by config change software.
Since I do not know what your trying to accomplish.., but a alternative to :execute is using :parse and another around it to execute it:
[[:parse ":export"]]
The software does not know which version of ROS the device is. It knows its a MikroTik but thats it, so it doesn’t know if it should run ‘export terse’ or ‘export terse show-sensitive’, the former for v6 and the latter for v7
I can specify which command to run manually, which becomes a massive administrative headache. Need something automated to run the appropriate command
I figured out why, ROS v6 will only read files up to 4kb in size, any larger than that they just return blank
I’ll try both suggestions tomorrow to see if i can make them work
If such is the case you will still have issue printing it after is generated from export command. Use :parse command as @Amm0 suggested.
Already done that before, but I can also make this for check what commands are supported and what parameters
http://forum.mikrotik.com/t/new-command-in-routeros-7/169237/34
[rex@MATRIX] > :put [$cmdtreeVar export]
export
(a) compact
(a) file
(a) hide-sensitive
(a) show-sensitive
(a) terse
(a) verbose
(a) where
So, with /console/inspect on v7 you can check supported commands, put on one string the correct parameters and run it with :parse for still on same session.
On latest version of v7 both show-sensitive and hide-sensitive are supported, so if is run v6-like command, is accepted.
Perfect, didn't know you could double wrap it. This is the answer and works perfectly
So here is the version agnostic command for anyone else who is interested
:if ([:tonum [:pick [/system package get 0 version] 0]] >= 7 ) do={[[:parse "/export terse show-sensitive"]]} else={[[:parse "/export terse"]]}
The problem is I need to be able to run just a single command and have it spit out output, since the software will read what is immediately after the command entered and store that as the config, can't run 2 commands or detect errors. And ROS6 is 'not' compatible with the show-sensitive suffix it couldn't be used
No this is not agnostic, this is wrong.
2022-02-26 Backup config to Gmail v1.7 - #5 by rextended resource
:if ([get version]~"^7") do={
} else={
/export terse
:local c "/export terse"; /sys resource;:if ([get version]~"^7") do={:set c "$c show-sensitive"};[:parse $c]
(fixed missing /system on 2nd time on original post)
We’ve been over this before, no its not wrong. It’s valid syntax for both v6 and v7
Getting the system package at position 0 is a completely legitimate way, feel free to explain to me why it won’t work and if you can come up with a valid real reason i’m happy to change it. The reality is there will ‘always’ be a package installed (otherwise ROS itself isn’t installed) and the installed packages are always the same version
Your method is more elegant but mine is not ‘wrong’
This is not the specific case, which may or may not work,
and it’s not even a question of code beauty or not (but why did you change it from the first post?)
but you absolutely must not use hardcoded numbers or .id to obtain values.
There are dozens and dozens of posts where users, copyng these errors,
make errors in the script and does not work…
Feel free to prove me wrong (and i’m more than happy to accept it) but there is absolutely no situation where [/system resource get 0 version] will ever fail or not return the expected result
If this were a different case where I was i.e. trying to get position 2 or return some arbitrary value, then sure I agree with you it’s a bad coding practice and it is not something I do. But this specific example it’s just being pedantic, it will always succeed and always return exactly the desired result on any ROS version. If you can prove to me otherwise i’m happy to eat my own words and give you props for it
With you what I write are empty words.
I have already made it clear that it is not a competition of style, or of right and wrong,
but of not leaving wrong examples on the forum.
Of course it works if a package is installed,
it is also easy to generate a problem, mixing packages of different versions,
but given the uselessness of those who do not want to understand, I do not waste time.
This would be you buddy
I literally asked you to prove me wrong and i'll happily listen and accept it. You on the other hand aren't listening at all, just preaching pedantic coding
I’ve already written the reason twice,
it’s you who comes out with this defiant air.
What do you expect me to write same thing “prove me wrong” and start a game of morons?
The other people on the forum will judge the situation,
I can’t help it if you don’t understand the things already written twice (and on other topics).
Whatever happens, this doesn’t mean that if you need help, I won’t give it to you.
http://forum.mikrotik.com/t/v7-18beta-testing-is-released/181371/1
Just wait new 7.18...
On different devices and different way of update I obtain different results.
This is one hAPax² from (??? not remember)->7.16.1 -> 7.17 -> 7.18beta2
Wrong way to get running RouterOS version:
[admin@test] /system/package> pri
Flags: X - DISABLED; A - AVAILABLE
Columns: NAME, VERSION, BUILD-TIME, SIZE
NAME VERSION BUILD-TIME SIZE
0 XA calea 20.1KiB
1 XA container 108.1KiB
2 XA dude 1224.1KiB
3 XA extra-nic 2220.1KiB
4 XA gps 24.1KiB
5 XA iot 548.1KiB
6 XA iot-bt-extra 148.1KiB
7 XA lora 8.1KiB
8 XA rose-storage 3136.1KiB
9 routeros 7.18beta2 2025-01-21 09:27:58 12.2MiB
10 XA tr069-client 132.1KiB
11 XA ups 32.1KiB
12 XA user-manager 332.1KiB
13 wifi-qcom 7.18beta2 2025-01-21 09:27:58 10.2MiB
14 XA wireless 856.1KiB
15 XA zerotier 832.1KiB
[admin@test] /system/package> :put [get 0]
.id=*3;available=true;disabled=true;name=calea;scheduled=;size=20625;version=
[admin@test] /system/package> :put [/system package get 0 version]
[admin@test] /system/package> :put [/system package get 9 version]
7.18beta2
[admin@test] /system/package> :put [/system package get [find where name=routeros] version]
7.18beta2
Correct way to get running RouterOS version:
[admin@test] /system/package> :put [/system resource get version]
7.18beta2 (testing)
If I netinstall directly 7.18beta2 (without check for updates) I obtain only
 #    NAME          VERSION    BUILD-TIME           SIZE
 0    routeros      7.18beta2  2025-01-21 09:27:58  12.2MiB
If I install later the wifi-com (without check for updates):
 1    wifi-qcom     7.18beta2  2025-01-21 09:27:58  10.2MiB
but if I upgrade from 7.17 to 7.18beta2:
 0    wifi-qcom     7.18beta2  2025-01-21 09:27:58  10.2MiB
 1    routeros      7.18beta2  2025-01-21 09:27:58  12.2MiB
after the check for updates:
 2 XA calea                                         20.1KiB
 3 XA container                                     108.1KiB
 4 XA dude                                          1224.1KiB
 5 XA extra-nic                                     2220.1KiB
 6 XA gps                                           24.1KiB
 7 XA iot                                           548.1KiB
 8 XA iot-bt-extra                                  148.1KiB
 9 XA lora                                          8.1KiB
10 XA rose-storage                                  3136.1KiB
11 XA tr069-client                                  132.1KiB
12 XA ups                                           32.1KiB
13 XA user-manager                                  332.1KiB
I almost feel like MikroTik has gone out of their way to screw it up in 7.18 just because of this thread :laughing:
I bow to you master, thank you for proving me wrong. I shall update the code to use the ‘correct’ syntax and not reference ID numbers from now on
Remember that no one is infallible. I often make mistakes too, especially with RouterOS that changes things with each version.....
For example... this do NOT work on 7.17+ but work on 7.16.2 and less (also on v6)... (first log is the directory, the second log is the prefix for create the file log.0.txt)
/sys log action set [find] disk-file-name="/log/log"
