Execute remote command
is there any option to send mass command to my MT’s in Dude?
I have over 50 MT’s and for example I want to reboot them all at once. It’s impossible?
Thank You.
You can reboot one router after another from ‘Device’ menu.
You can upgrade multiple routers at once, by using ‘Device’ and ‘Groups’, but reboot as far as I know is not available for multiple routers.
