Experience Patching ROSE servers
Hello everybody,
I have a ROSE running 2.24 in production. Two RAID6 Arrays served as NVME-over-TCP to proxmox.
It is working perfectly.... but I need to plan the upgrade path for this device.
Has anybody else running a rose in production upgraded routerOS versions with live data?
I have previously copied everything off, upgraded, and moved everything back.
but I'd love to have confidence (maybe backup everything first ovbiously), but just upgrade the storage server without the whole runbook.
Hi
2.24 or 7.24?
I would wait till 7.25.1 at least or even 7.25.2 as 7.25 is not production ready yet.
There are some functions and/or devices in critical places within an organization that don't need to be patched every single time there's an update. Storage is one of those. Switching is another.
Unless there are features or fixes that you can't get along without on an otherwise perfectly running system, updates to them can go over longer cycles.
7.25 hasn't been out for but a couple days, and hasn't even hit a point release. I'd wait it out.
All that said, If you have a solid, trusted backup, then a normal update-in-place is fine. You just have to schedule downtime for your clients, whatever they may be.
Sorry to state this but you're both being literal.
Imagine if you were.. sometime in the time and space.. a rose server on 7.23 or any other previous version
Has anybody ever upgraded a rose server in prod with live data to from a lower version to a higher version?
is there risks? concerns? or is the upgrade path as valid as any other ROS upgrade which is pretty damn good.
Serving two RAID6 arrays over NVMe/TCP to Proxmox from one ROSE box in mission critical production takes guts. Said kindly. Mostly.
Two honest questions first. Did you do a real risk analysis on that? ROSE rides the RouterOS release train, it's not a storage OS with its own LTS. And I assume you have continuous backups and a tested warm/cold restore DRP/BCDR? RAID6 covers dead drives, not a bad upgrade or a dead box.
It's also a single point of failure, so plan a maintenance window anyway. Stop or migrate the Proxmox VMs first, test on spare hardware or a CHR, read the changelogs up to your target and keep a config export plus the old package for rollback. And @sirbryan is right, storage shouldn't be upgraded just because a new release is out. 7.25 has had an unusually rough start, so I'd stay far away from it for a long time. If anything, look at long-term.
Being literal is kind of the job in storage. Good luck, hope it's a boring one! :slight_smile:
I did. It was fine. I think I did it a couple of times without too much hassle, except my containers broke once or twice. I did find a race condition where, when ROS crashed the ROSE server, and when ESXi reconnected the NFS share before ROS was completely "up," ROS handed it the wrong filesystem and my VM's freaked out and couldn't be restarted until I disconnected and reconnected the NFS share. MikroTik just acknowledged the problem a week or so ago and said it was coming in a future patch.
I also noticed (when I first got it) that adding an NVMe drive under RouterOS causes the machine to kernel panic.
I've since migrated my ROSE machines to TrueNAS on the bare metal and that no longer happens.
Oh wonder :roll_eyes:
It's also nice to run a current LTS kernel on it. :wink:
