hello
in the hotspot profile configuration theres a session timeout, idle timeout and keepalive timeout, whats the difference between keepalive and idle timeout?
hello
‘idle-timeout’ is used to detect, if client is not using Router networks, reaching timeout user will be logged out, etc.
‘keep-alive-timeout’ used to detect, if is available and reachable, if check fails client will be dropped out, etc.
in other words, idle timeout checks traffic, keepalive timeout checks availability. if user is online but is just not sending./receiving anything, he may reach its idle timeout. keepalive timeout may only be reached if client is physicaky disconnected or turned off.
As far as I know keepalive timeout monitors the client’s workstation by pinging the client. So if the client has a ICMP block on their firewall keepalive timeout should not be used.
thanks very much
Many of our users are always complaining that they are getting logged out always and when I checked microtik logs, it says keep alive timeout.
So is there a way to switch off keep alive feature and use idle timeout ?
If yes, then where ?
hello all,
so how to disable both of and , i mean i so not want the router to use them… so the hotspot user is not disconnected.
at least to disable ; so if the user is not using the network he is not disabled from the network and not being required to insert the username and password again…
