export map
Please if possible to have an option to auto export the maps on a directory in order to use them in a public web server without the need for login/password. For example auto export map as .png every X seconds in a specific directory.
Thank you
yes…this would be great…
especialy until web server will work :slight_smile:
tell me please when we can export .PNG network map ??
Manually you can export network maps already by opening network map and going to Tools → Export → PNG. Automatic periodic exporting is sitting in TO DO list.
