Hello all,
Newbie here.
I have Mikrotik hap ac2 with the latest version of Router OS ( version: 6.43.8 ).
I have an ADSL connection as primary and LTE connection via Android Tethering as secondary. I route both ADSL and LTE via Mikrotik. I want to use Mikrotik router for failover. Manual failover is okay for me, and it works too. I have an issue with the (manual) failover.
As a first step, I linked ADSL connection to Mikrotik’s Ethernet 1 port and used Webfig->Quickset for the initial configuration.
Then, I connected Android phone via USB tethering, created firewall NAT rule (chain=srcnat action=masquerade out-interface=lte1 log=no log-prefix=“”).
Modified DHCP clients to never “Add Default Route”, so that I can add routes manually.
Deleted existing routes at IP => Route and created them manually. Now, I can switch between both internet connections manually. I can see my public IP has changed whenever I change the route (aka internet connection from ADSL to LTE or vice versa).
The issue is when I switch between ADSL to LTE, all existing connections (for example, ping to 1.1.1.1) that originated from ADSL doesn’t switch to LTE automatically (ping command shows timeout). Similarly, when switch from LTE to ADSL, all existing connections that originated from LTE doesn’t switch to ADSL automatically. For example, I had to restart the browser in order to use the newer internet connection.
Please know that the same ping command, if I issue from within Mikrotik router (/ping 1.1.1.1), the ping keeps going when I switch the routes. I hope you all can understand what I am trying to say or do.
Here’s output of /export hide-sensitive compact
# feb/01/2019 10:27:19 by RouterOS 6.43.8
# software id = KBW2-46HF
# model = RBD52G-5HacD2HnD
# serial number = xxxx
add admin-mac=xxxx auto-mac=no comment=defconf name=bridge
/interface lte
set [ find ] mac-address=xxxx name=lte1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-20C6B3 wireless-protocol=\
802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=india disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-20C6B4 \
wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add add-default-route=no comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add add-default-route=no dhcp-options=clientid,hostname disabled=no interface=lte1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat out-interface=lte1
add distance=1 gateway=192.168.75.1
add distance=2 gateway=192.168.42.129
/system clock
set time-zone-name=Asia/Kolkata
/tool mac-server
/tool mac-server mac-winbox
What did I miss to do for a smooth failover of internet connection on my PC?
