I have a CRS312-4C+8XG. I want to make it quiet. So I started experimenting with the Minimum Fan Speed Percent setting. It looks like the lowest setting the system will accept, and still run the fans is 20%. It does accept 0%, which makes the device silent.
Fan Min Speed Percent Fan RPM
50% 7725 → 8205
40% 6300 → 6705
30% 4545 → 4860
20% 3975 → 4260
10% 3960 → 4230
5% 3960 → 4230
0% 0
Question - How accurate are the RPM readings? If you trust them, can you please enable 10%, 5%, 1% settings? I’d love to have the fans constantly turning at about 400RPM. I feel that would keep my system cool, and be silent.
