fasttrack downloads, queue uploads, possible?
At home my bandwidth my ISP provisions for me is not symmetrical. I noticed that when using a rule like:
add action=fasttrack-connection chain=forward connection-state=established,related in-interface=vlan2
both incoming and outgoing packets are fasttracked.
Is there a way to fasttrack packets in one direction only?
Reason I’m asking is that I have 360/36 mbps at home and I’m trying to use a hAP ac my home router, and I’d like it to only shape uploads since it is too slow to deal with the download bandwidth without fasttrack.
I am afraid not. If you are fasttracking a connection, all belonging packets are bypassing the firewall.
I wonder if I can hack it somehow to have the router os think the connections are separate.
Or what if I had asymmetric routing, such that I’d route all uploads from home lan through a meta router and then through wan and all downloads from wan directly to home lan.
Would fasttrack break such a setup?
Disable FastTrack and use DSCP queues instead.
http://forum.mikrotik.com/t/dscp-mangle-and-queue-trees/100297/1
@IntrusDave: not what I was asking:
  1. I want fasttrack for more performance
  2. sfq+limit for upload works fine.
The problem is that both don’t work at the same time, i.e. fasttrack for downloads, sfq for uploads.
FastTrack and queues don’t work together. FactTrack by definition bypasses all filters and queues.
I know that’s what gives fasttrack the performance, I just wasn’t expecting it to be both directions or none.
Queues and filters can certainly work in one direction only, not sure why fasttrack would be both or none.
FastTrack works on a connections. A connection is bidirectional.
