Feature Request: export sterilized
It would be nice if we could do an export that would automatically sterilize the output to post to the forum. It should be pretty easy to do from a code perspective. Remove addresses/passwords.
without addresses, you can’t tell if the config is correct or not. some information should not be “sterilised” or at least should be done selectively
