My understanding of FullCone NAT is as follows, if there are any errors, I welcome correction:
We first assume the following environment data:
PC1 192.168.88.100
PC2 192.168.88.200
LAN 192.168.88.0/24
WAN IP 34.56.78.90
The destination to be visited is 1.2.3.4:2345
When a device PC1 in the LAN network visits the destination UDP://1.2.3.4:2345, then there will be a record in the NAT table
src-address = 192.168.88.100:2345
dst-address = 1.2.3.4:2345 / reply-dst-address: 34.56.78.90:12345
When a device PC2 in the LAN network visits the destination UDP://1.2.3.4:2345, then there will be a record in the NAT table
src-address = 192.168.88.200:2345
dst-address = 1.2.3.4:2345 / reply-dst-address: 34.56.78.90:23456
At this point, as the visited person 1.2.3.4:2345, you will see two requests respectively from 34.56.78.90:12345 and 34.56.78.90:23456 UDP requests.
If we want 1.2.3.4 to be able to return the data normally to 192.168.88.100:2345 and 192.168.88.200:2345,
then we need to add two dstnat mappings to 88.100 and 88.200, respectively.
The problem now is that 12345 and 23456, the two WAN ports bound to the NAT table, are random, that is, if the NAT table expires.
Then perhaps 10 minutes later, when the two PCs visit 1.2.3.4:2345, the NAT table will allocate two new ports, which can be any unused UDP.
We can solve this problem by recording every request from each device in the network and setting the corresponding port mapping.
Of course, someone says we can read the NAT table and then write the dstnat rule, congratulations on what you said, and I have implemented it.
But there will be a situation, you need to cycle this thing at a certain time, when you write the rules according to the known request,
the relevant data has returned to the port, but it has not reached PC1 / PC2 correctly and then failed on the APP on PC1 / PC2.
Similar problems are like the dns-to-address-list currently supported by RouterOS,
I have also written the script this way, by traversing the dns cache, and then reading the record and writing it to the relevant address-list according to the domain name you need.
That is, dns-to-address-list is implemented by the script, but you will find that many times
when the client visits the destination, the expected record has not been written to the address-list by the script.
It is still not possible to rely on the script alone when more and more devices in the system need fullcone NAT.
You need to make RouterOS internally support this feature.
Regarding security concerns, Fullcone NAT now comes with a device list feature, similar to a DMZ list. This means that only devices on the list will be subjected to Fullcone NAT. Of course, if there is malicious software on your computer, it will increase security risks. However, this is no different from the security risks of UPnP and is considered a disclaimer.
