Would it be possible to increase the accepted upper limit of the RADIUS client timeout from 10000 ms to - let’s say - 45000 ms ?
I am currently testing two-factor authentication (2FA) from Duo Security. I was able to successfully set it up to work with Mikoritk for VPN users authentication, the only issue that I have experienced so far occurs when user is in places with poor WiFi/mobile phone network coverage. In such a case the request usually time-outs before the user gets the notification to confirm login, using the installed Duo application, on his or her smartphone(I am testing the Duo Puch option).
