Feature Request: Restore ability to remove dynamic Queue
MT,
Would you be so kind if you could restore the functionality that we can remove dynamic simple queue on the fly via up/down script in PPPoE profile and create the simple queue to our liking?, our solution relies on this heavily and we can’t move our BRAS/PPPoE concentrator to v7 latest stable version because of this, I believed a lot of people depend on this unintended feature if you will, because based on the other thread normis flatly said that’s they way it should work, We build a lof of custom solution because of this unintended feature now been closed without giving us alternative or workaround, we have a lot of CCR1036 about to die in the field without suitable replacement because of this.
For your consideration
