Feature Request: Support for RFC 7599 (MAP-T) in RouterOS
Dear MikroTik team,
I would like to kindly request the implementation of RFC 7599 – Mapping of Address and Port using Translation (MAP-T) in RouterOS.
MAP-T is a standardized IETF protocol designed to provide IPv4 connectivity over IPv6-only networks. It is currently adopted by several ISPs, including some operators here in Italy (eg. Sky Wifi), and is becoming increasingly relevant in IPv6 transition strategies.
Supporting RFC 7599 in RouterOS would greatly improve its interoperability in modern network environments, particularly where native IPv6-only deployments are in use and MAP-T is required to provide legacy IPv4 services.
I hope you will consider adding MAP-T support in a future RouterOS release.
Best regards,
Fabrizio Borelli
Yep. I agree with this.
Support for Map-T/Map-E is important and it shouldn’t need a separate container (e.g Jool) from RouterOS to run it.
I agree, this function is fundamental for me too
This is a little late, but I found a post that describes how to do MAP-E on routeros.
