Replying to an old post, but there is actually a better way already. You can use the IFTTT Maker channel. This will give you an URL to use in RouterOS fetch tool.
Then make a new recipe, with some kind of action. The “If” part would be the Maker trigger.
Then in RouterOS you can use Scheduler or Netwatch to do this:
