#1) In the winbox Registration screen (where your AP shows all the connected clients), I would like the ability to bump off a connected client for a given amount of time 1 to 10 seconds. This may be usefull go get a client to change/roam to another access point or another WAN card on the same AP.
#2) In the winbox Registration screen (where your AP shows all the connected clients), I would like the ability to sort TX/RX traffic & rates for both UP and down information. Currently, you can not sort by client up TX information.
#3) I would like to have the ability to remotely perform a (Freq Usage -and/or- Scan) and be able to view the information when the client re-connects - or do so without disconnecting the link.
#4) Without a bunch of scripting - I would like to have an AP accept client connections only if the client has stronger than a minimum signal strength programmed into the AP. Example, An AP might be set to only accept client connections with a signal strength stronger than -75 —and— I would like the ability to auto drop clients if their signal strength falls under a pre-determined signal strength. This feature for minimum strength to connect and strength to disconnect could be used to enhance roaming between APs. Currently a roaming client changes to another AP only when the is looses a link.
#5) I would like the ability for a 2.4 GHz AP in G-only-mode to not accept client 1-meg upload data rates. (I think this is a bug in the current system). Example, With an AP in G-only-mode and only G rates checked - it is possible to have clients connected with a normal G rate down and a 1-meg-B-rate up. (Example TX/RX rate = 24Mbps/1Mbps). I see this over and over on many G-only APs.
#6) I would like the ability for a client with a 2.4Ghz/5Ghz card connected to dual-band antenna (or two antennas) to be able to roam between bands. Example, I have a roaming client (a car or something) In one area I have a 2.4 Ghz AP and in another area I have a 5Ghz AP (both same SSID and encryption -and- same bridged IPs on the WANs). The only way I know to do this today is with two cards (one a 2.4 and the other a 5Ghz) and let spanning tree do the work. It would be nice if one card could do this.
#7) I would like the ability for a client to auto go through 5-10-20-40 Mhz wide channels to connect to an AP.
