Another feture request regarding links: make it so you can create an SNMP link that gets it’s SNMP data from another source then one of the link ends.
Example:
This is handy if you’ve created a link between a manageable router and a ‘network cloud’ device and then connect several PC’s to that cloud. I would then like the links to be able to use SNMP data from the switch, but this is currently not possible. (Connecting all links directly to a 48 port switch [or even a 24 port one] will crowd the map too much.)
