Filtering traffic between wireless clients
Hello.
Sorry for my pure English.
I have 1 AP RB912. Eth1 and wlan1 add to bridge. How filter icmp traffic between wireless clients?
add action=drop chain=forward mac-protocol=ip ip-protocol=icmp src-address=10.30.0.0/26 – does not work
add l2mtu=1600 name=br1
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode \
    band=2ghz-b/g basic-rates-a/g=\
    6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b="" \
    bridge-mode=disabled country=russia default-forwarding=no disabled=no \
    ht-rxchains=0,1 ht-txchains=0,1 hw-protection-mode=rts-cts l2mtu=2290 \
    mode=ap-bridge periodic-calibration=enabled rate-set=configured ssid=\
    WL1 supported-rates-b="" tx-power=27 tx-power-mode=card-rates \
    wireless-protocol=802.11
/interface bridge filter
add bridge=br1 interface=ether1
add bridge=br1 interface=wlan1
/interface bridge settings
set allow-fast-path=no use-ip-firewall=yes
/interface wireless access-list
add interface=wlan1
add address=10.30.0.2/26 interface=ether1 network=10.30.0.0
set servers=192.168.193.10
add distance=1 gateway=10.30.0.1
/system leds
set 0 interface=wlan1
/system routerboard settings
set cpu-frequency=600MHz
Instead of trying to limit in the bridge firewall, try to limit in the IP firewall. That setting is already set to yes on the bridge anyway.
Problem is not closed.
If disable default forwarding then all traffic not forward between wireless user.
If enable default forwarding then it is impossible to control traffic and filter.
Conneсt each users to individual virtual ap its not good. AP should be open
Help me please.
I was trying to achieve the same.
Packets coming in on a bridge port are prevented going out on the same port. On linux (which RouterOS is based upon), bridges support ‘hairpin’ mode [1] (don’t confuse with hairpin NAT), which would allow filtering between devices on the same AP/interface, but RouterOS doesn’t support it.
[1] http://man7.org/linux/man-pages/man8/bridge.8.html
I would suggest making a feature request to the support mail address.
Did you find a solution here?
I posted a new post yesterday quoting yours - it’s an old one so I didn’t think it appropriate to continue your thread but here’s my post http://forum.mikrotik.com/t/bridge-filtering-client-to-client-traffic/171162/1
We can do L2 NAT so I think it might be possible to pull some kind of trick. It’s important because IOT devices often use unsecure UPnP discovery methods and we need to be able to satisfy their functional needs whilst preventing them from doing anything else.
