Hi folks,
I can’t create script to change mask range in services. I need to find the searched ip address (X.X.X.X/29) and change the given range (X.X.X.X/28). Is this variant possible?
Thank you for your help!
ip service
:foreach value in=[find address] do={
:foreach address in=[get $value address] do={:put "$address -> $[:pick $address 0 [:find $address /]]/28"}
Output:
X.X.X.X/X → X.X.X.X/28
This is the basic algorithm. Now you can modify the script according to your requirements (replace “put” with “set”, change the search condition, etc.)
